Which Wideband would you guys recommend??
Originally Posted by dmc_racer
Will this one work with our trucks??
http://store.summitracing.com/partde...?part=ATM-3375
http://store.summitracing.com/partde...?part=ATM-2244
LS1TECH Sponsor
Here's a listing of some of the widebands people are using with our software/hardware package http://www.hptuners.com/forum/showthread.php?t=10510
I am using the Autometer Wide Band AFR Gauge and really like it. I had to set up a user defined PID for HP Tuner Logging but other then that it was easy. I can log with HP and watch the gauge. I put the Wide Band Sensor 6" after the Cat on Bank 1 and it reads real stable, not over sensitive.
Resident Retard
I was told to do this because the Wide Band Sensor doesnt like Heat or Pressure. It actually reads great. If it is a little lean then I will always be safe. I tune by using the stock sensor and the wide band readings logged side by side.
