wierd bank 1 ltft
Moderately Differentiated
After making a histogram that has LTFT Bank1 and LTFT Bank2 seperated, it looks like you might have a vacuum leak on one side... Notice the difference between the sides... Leaky intake perhaps or a leak around the injectors.... I would log the trims at idle and spray the crap out of it with some carb cleaner and see if the trims change..... Looking at the histogram the problem is across the board, not just at a certain MPH...
VE Bank1 LTFT
VE Bank2 LTFT
MAF Bank1 LTFT
MAF Bank2 LTFT
VE Bank1 LTFT
VE Bank2 LTFT
MAF Bank1 LTFT
MAF Bank2 LTFT
Man, it's gotta be a vacuum leak or something pre-o2. Unless your o2 is toast. Swap your o2's make sure the problem doesn't stay with the sensor.
i have sprayed all over the intake with a full can of supersized carb cleaner it did not move the trims a bit. so , how else do you detect the leak?
