wierd bank 1 ltft
#23
Moderately Differentiated
Make extensions and swap the o2 connectors.
Go open loop and stick the wideband in that bung. Log for awhile and then stick it in the non-problem bung and compare the two wideband histograms. If that bank is considerably leaner then you know you have an issue and must keep trying to find the pre-o2 leak, albeit whatever.
If your wideband is showing rich during closed loop (you said 13:1 earlier) then I'd guess the problem is after the motor before the sensor. PCM is adding fuel for a problem that isn't there and causing a rich situation.
#26
hmmmm. well i took the sensor in bank 1 out again last night and noticed a peice of weld inside of the bung. it may have kept the sensor from going all the way in. i tapped it out and im gonna go log here in a lil while. im exhausting all options before tearing into the motor.
dantheman1540
02-24-2016 09:56 PM
creekrat
09-10-2015 12:59 AM
