wierd bank 1 ltft
Old 08-11-2008, 10:10 PM
  #21
Resident Retard
BlackGMC's Avatar
Originally Posted by dewmanshu
my bad... can I excuse myself due to drinking?
drunkin postin, second to drunkin dialin....
Old 08-11-2008, 10:14 PM
  #22
Un-Registered User
mcfarlnd's Avatar
hell yeah. im getting wasted in hopes itll fix my truck.
Old 08-11-2008, 10:34 PM
  #23
Moderately Differentiated
dewmanshu's Avatar
Make extensions and swap the o2 connectors.
Go open loop and stick the wideband in that bung. Log for awhile and then stick it in the non-problem bung and compare the two wideband histograms. If that bank is considerably leaner then you know you have an issue and must keep trying to find the pre-o2 leak, albeit whatever.
If your wideband is showing rich during closed loop (you said 13:1 earlier) then I'd guess the problem is after the motor before the sensor. PCM is adding fuel for a problem that isn't there and causing a rich situation.
Old 08-11-2008, 10:42 PM
  #24
Resident Retard
BlackGMC's Avatar
I just got off the phone with him, do yall think a bent push rod would cause the problem?
Old 08-12-2008, 05:06 AM
  #25
dewmanshu's Avatar
YES...wow.
Old 08-12-2008, 12:41 PM
  #26
Un-Registered User
mcfarlnd's Avatar
hmmmm. well i took the sensor in bank 1 out again last night and noticed a peice of weld inside of the bung. it may have kept the sensor from going all the way in. i tapped it out and im gonna go log here in a lil while. im exhausting all options before tearing into the motor.
Old 08-12-2008, 03:22 PM
  #27
Un-Registered User
mcfarlnd's Avatar
nope still @#$ked. added another log to the first post.
Old 08-12-2008, 08:35 PM
  #28
v8
17,16,15,14,13,12,11 Drvr
post up your tune or send me a pm with it.
Old 08-13-2008, 02:40 AM
  #29
Un-Registered User
mcfarlnd's Avatar
i swapped injectors, retorqued the header bolts and checked the pushrods (still good) this evening and ill log tomorrow. added tune
Old 08-13-2008, 11:08 PM
  #30
Un-Registered User
mcfarlnd's Avatar
still no luck. i went sdol today till i can figure it out.
Pimpinpete
43
12-22-2017 08:13 AM
dantheman1540
02-24-2016 09:56 PM
02AWDAWSDenali
10-01-2015 05:08 PM
creekrat
09-10-2015 12:59 AM
Quick Reply: wierd bank 1 ltft
