Wiring help
I plugged the green wire into the empty 42 slot on one pcm harness and the blue wire into 33 slot on the other. One pcm harness had only 42 open so that's where I plugged in the wire. And vice versa.
It was confusing at first cause the pcm harness had one side with a blue plastic clip and green plastic clip.
Are the fans supposed to run without the tune? I was under the impression the fans will run on low until I get it tuned for them to run properly?
