Wiring the LM7 for AEM - sensor questions
I'll be wiring from scratch the whole harness, so there won't be many things from the stock harness that I'll need.
What I have:
LS1 throttlebody
80lb injectors (bosch clips I believe)
Fuel from two pumps (A1000 and Walbro 255)
IAT will be a standard GM model
What I have on the list for wiring:
injectors
IAT
TB: Idle air and TPS
knock
fuel pump relay
coolant temp
coilpacks
What I'm not sure about is crank and cam sensor locations. Also, I'm sure I've forgotten something; it's early in the morning.
I haven't started yet, so I thought I'd get some input from you guys since this my first V8 swap. This is also my first AEM; installed megasquirt on my other cars.
Thanks,
Donnie
What I have:
LS1 throttlebody
injectors
IAT
knock
fuel pump relay
coolant temp
coilpacks
Thanks,
Donnie
lxcoupe
07-30-2015 03:42 PM
