WOT shifting ???
Originally Posted by RandomHero
seems a bit obvious but you changed the shift times to 0.00 right?
0.00?? I didn't think the shift times were supposed to go any lower than like 0.200. I may be misunderstanding you.
Originally Posted by gmforlife
The only way to get a "FREAKISHLY HARD" shift is a shift kit, if you maxed out line pressure and shift speed, i don't think you would get the above result. Every truck is different, and maybe this one has more miles, or something is mechanically wrong in 2nd gear or something.
In my 2000 silverado, it would shift so hard that it would hurt. Stock tranny with tuning only. Shift speed was maxed out but I never maxed out the line pressure in fear of smoking the tranny. Maybe it was just my truck, but it shifted "VERY" hard for just tuning.
Originally Posted by v8
your 1-2 shft times are like .587 move them down to .200 and leave the shift firmness stock or bump it up +10 from 246tq to 640tq not to exceep 90 psi in any column.
good luck.
good luck.
I moved the shift times down to .200 and worked on the firmness a tad with no result. I told him yesterday that he will probably just have to get a shift kit because if I messed with the pressures too much more then I would be afraid that it would kill the tranny. It still makes no sense that it shifts exactly like I expected it to from 2nd-3rd. but 1st-2nd just will not respond to the tuning changes. Thanks for everyone's replies.
Like i said, i find that hard to believe. My 60 shift SUPER HARD, chirped the tires at WOT 1-2 on a 6000 rpm limit with 20"s, now that's freakishly hard, and that was a transgo. Granted my line pressure was way too high at the time, hadn't retuned it and all my computer and interface got stolen so i had to drive it around like that for 6 months, probably the cause of death on mine. But if you have a 60 shifting that hard with 0 TM it's not gonna last too long if you are throwing a good deal of power at it.
I didn't say that was a tune that I regularly put in trucks. I am just saying that I have made quite a few trucks shift very hard. It was spinning going from 1st-2nd. Believe what you want but I have tuned 5 trucks around my area and they all shift pretty hard. All have 4l60e. Now I agree that the tranny may not last with these settings...that is why I have advised them to get shift kits and most of them had. I basically just put this tune in this guy's truck to see if that would make any difference and it did not. There are a lot of guys around my area chirping the tires from 1st-2nd with tuning only.
And when I say FREAKISHLY HARD, I do mean FREAKISHLY HARD for tuning only. I know that with tuning only it will not shift like it does with a shift kit or servo. Don't get me wrong in that aspect. I know there is a difference.
lukn4trbl355
10-21-2015 11:19 PM
