Write entire or write calibration only when doing a segment swap?
Old 09-03-2011 | 09:34 AM
phasemaster1's Avatar
Default Write entire or write calibration only when doing a segment swap?
Do I write entire or calibration only with segment swap? Thanks
Old 09-03-2011 | 01:50 PM
slow67's Avatar
Gingervitis Addict
Better safe then sorry, just do a write entire.
Old 09-03-2011 | 03:48 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
Never Write Entire unless you have a patch to install or a Custom OS.
If you change the speedo segment you will not need to rewrite the other 7 segments of the file. If you have an issue when writing the speedo segment then the OS will be intact and you will be able to reprogram just that segment.
If you have an issue in the write process and you had choses the Write Entire then it is possible that your PCM will be bricked and you will need a replacement.
If you have made adjustments in 7 segments then by not selecting the Write entire you will just update the segments that have changed
Old 09-03-2011 | 05:51 PM
slow67's Avatar
Gingervitis Addict
Right, but I have had several people tell me that they had trouble with a transmission segment swap when they did a write calibration only. A write entire fixed it.
Old 09-04-2011 | 02:08 PM
Well I did both starting with calibration only the entire Im having some codes come up think p0758,p0748 and another trans temp on dash not working going to check harness connection.
Old 09-04-2011 | 05:34 PM
Who would have thought the transmission harness plug fits upside down. Fixed
XL7
05-05-2022 02:48 PM
lo&sloSierra
08-30-2015 03:36 AM
1slwgto
08-16-2015 07:40 PM
creekrat
08-02-2015 02:27 AM
Quick Reply: Write entire or write calibration only when doing a segment swap?
