ZL1 Colorado
Old 11-17-2012, 12:24 AM
  #81
Mod with training wheels
smokeshow's Avatar
All correct, andy lol... but i am referring mostly to the fact that it says its making near 23psi. Nevermind the other bullshit, how is that even possible? Lingenfelter was surprised when they heard it was making 20...and then i see 250kpa on the scanner today.
Old 11-17-2012, 12:29 AM
  #82
11 Second Hall Moniter
AKlowriderZ71's Avatar
Is there a mechanical boost gauge on this thing, to verify that the MAP sensor (or wiring) isn't on the fritz??
Old 11-17-2012, 12:40 AM
  #83
smokeshow's Avatar
No mechanical boost gauge. I want to put one on after seeing that number, though... The most interesting part is the corresponding drop in fuel pressure seems to support the MAP sensor's claims.
Old 11-17-2012, 12:43 AM
  #84
Does this truck have a fuel pump control module?
Old 11-17-2012, 12:55 AM
  #85
smokeshow's Avatar
It does have the FPCM. Also has the handy little bleeder valve in the fuel bucket that prevents fuel pressure from exceeding around 70psi. So at full boost it drops below 50 every time.
Old 11-17-2012, 12:59 AM
  #86
Makes me wonder if the FPCM uses MAP sensor data to control fuel pressure. I bet it does, somehow. But...... I have no idea how that helps.
But it does bring me back to the question of, is the MAP sensor info correct?
Old 11-17-2012, 10:32 AM
  #87
Area47's Avatar
Originally Posted by smokeshow
Anybody see anything wrong with this picture?
250kpa @ 2700
-9 degree's of timing
desired vs actual fuel pressure
cmd afr vs actual
thats just off a quick glance.
Old 11-17-2012, 11:16 AM
  #88
smokeshow's Avatar
Not sure if the MAP is correct. Should be finding out today... And Area47, that desired pressure is EPC desired pressure, not fuel. But yes overall, pretty fucked up. lol
Old 11-17-2012, 09:00 PM
  #89
Area47's Avatar
ah, i see.
whats going on with the commanded afr vs the wb?!?!
Old 11-17-2012, 09:51 PM
  #90
smokeshow's Avatar
Wideband is a flatline lol. There's nothing in the input.
Quick Reply: ZL1 Colorado
