9mm or 40?
9mm or 40?
looking at getting 2 new handguns. have 3 revolvers, looking for a semi auto. ave looked at several of both types. leaning towards the 9mm. what do you guys think? any particular brands?
Whatcha looking for purpose? I've got a .40 FNP and love it. Its a bit on the large side to carry though. I still want to get a 9MM as I personally feel I'm much more accurate with a 9mm. Best bet would be to go to a range that rents firearms and try several of the weapons that you might be interested in.
My next one will be an H&K USP 9mm.
personally i'd recommend a 9mm because they're great to practice with at the range and get comfortable with and loaded with the right ammo they're pretty effective at stopping people. in my opinion the .40 S&W is a perfectly fine round that is effective, cool and yet has no real reason to exist when you can get a 9mm that holds more ammo in the same frame size, is cheaper to practice with and will defend you and yours just as well or you can get a .45 and load it with gentle ammo if you want to make a bigger hole without the extra kick...but in the end, go with what feels best to you, assuming you have an adequate caliber choice, confidence and comfort with your piece are the next most important things...
A 9mm in a QUALITY JHP will be sufficient for defense, and will be cheaper at the range.
If you believe the caliber war hype, buy the .40 S&W and get a conversion barrel, which is what I did.
