Dpms AR-15 trigger issues
I was at the range Saturday shooting. I put about 100 rounds through my rifle when the trigger got really hard. It would still fire but was stiff as hell. I had 120 rounds with brass casings, and 40 rounds with steel casings. Didn't load the steel until the last few clips and then I started having issues. Any ideas?
I had a primer blow out and get stuck under my hammer and lock mine up.
Take the upper off, hold your hand on the hammer very slighlty.
Pull the trigger and see what everything is doin.
Called a function check.
Possible a trigger or hammer pin broke.
Ive had that happen a few times.
Take the trigger group apart and inspect it and snap picks
Function check
Charge handle
Switch from safe to semi
Pull triger and hold down on trigger
Charge handle again
Let go of trigger should hear a click if so all good
I'm thinkn your bolt is dirty between firing pin and bolt set bolt in some carbon softner or gun oil and clean it up and clean ur triger assembly and oil sounds like little dirt or carbon build up 100 rounds in a ar gets dirty quick
Charge handle
Charge handle again
TAPyvehc93
09-14-2015 01:22 PM
