I'm building my upper...toss ideas and info!
Both tolerances can wear over time, New Polymer Lower on the market
Plumb Crazy Lower
Polymer lower recievers?
This isn't for anything crazy, just a budget build. The polymer lowers are getting the same **** the Glock first got, and yet many people have shown that they perform well, and I have yet to see real proof of one failing. There is a pic floating around of one cracked by the rear where the tube threads into, but it was said he did it purposely. The ears can break of forged lowers while installing the trigger guard, so nothing is perfect.
But please, can we stick to the thread title and not my lower.
Plumb Crazy Lower
Lmao black rain is a complete joke.
The snythetic lowers will wear over time and can easily break, but I also build stuff that is far more precise than out of the box stuff. The next AR I build will be done on a seekins precision upper and lower.
Nothing wrong with lower budget builds at all just expect lower budget results. I don't and will not own anything that shoots more than .5 MOA.
Ha about the lower, its actually not like a glock or XD. The pistols have a metal slide, metal inserts that the plastic house for the slide to ride on.
And the plastic lower your running is all plastic, with metal pins that run thru it.
But on a serious note, dpms slick sided upper $70 on sale some times, black hole weaponry barrel or a RRA M4 barrel, theres a guy here in MS thats sellin M4 barrels 7 twist chrome lined chamber and bore for 120 or 130?
Be something cheap to get started with.
I like the yankee hill machine customizable free floatin hand guards, YHM lopro gas block, and a gas tube.
And then all you need is a Bolt and charging handle.
My point was polymer construction, and you can run a mil-spec LPK in these, I am not because it will do me fine for now as is. I keep reiterating that I have a built 6.8 for the "tough" stuff.
I do not like the looks of M4 barrels, that step notch (lacking technical term) looks dumb imo not being used.
I will use a BHW most likely, I like what I have read and heard so far.
I like my YHM Diamond so far, light enough, and quality.
I still need to get a few tools, bench vise, and the blocks. Doing this **** without proper tools creates a headache, and for a first timer, there is already enough!
I put the first 5 together with nothing but a vice and some punches wih a small hammer. Still dont have that lil pin holder thing. Pretty much got use to assembling with out it.
