M1A vs AR15
These are lowers.
The lower receiver is the part of an ar that has the serial number on it so it is technically the "firearm" and that will be the part outlawed if it happens. So if you've got the lowrr already as availabikity of parts to finish it off become available you can do it. Rather than paying the ridiculous prices people are charginf now.
An AR lower is an AR lower pretty much, just get an aluminum one. The polymers require some fitting occasionally. The billet lowers are basically just pretty but I sure like my pretty stuff
I got it under 6.2 lbs scoped, but with no mag.
This is my Billet Specialized Dynamics lower on my 6.5 Grendel, SWEET, but HEAVY!
When has strength in a forged lower been a problem though? The lower doesnt recieve really any force during firing and there are guys on the 458socom forum using polymer and forged lowers quite often. Check out the posts by a guy named Big Bore. The 458 probably packs the heaviest punch of all ar15 cartridges and the only problrm they've really had was with the bolt lug on the feed ramp breaking off not with the strength of lowers. The billet lowers are just pretty and expensive pretty much, but I like em.
Its not normally a problem. I do know a few guys that hunt a very large number of hogs with heavy weight 50 Beowulf loads that have seen the upper/lower receiver pins start to egg out the holes in the receiver. But you are talking about lots of 350 g+ high recoil ammo being fired. The .358 wssm can be tough on them as well. But I doubt it would be a problem for the normal shooter. The billet lowers being machined from slightly harder grade of aluminum hold up a little longer.
Frito Bandito
03-24-2012 11:24 PM
